The 2009version upgrade to version 2011how to do?
Hello duyonglu,
I'm glad you solved your issue. If you have any other questions, please let me know.
Hi
UtralWebGrid can Use UtralWebGrid.Rows.Add() Method but on WebDataGrid can't use this Method.
Thanks!
Hi duyonglu,
It seems that you are using some controls, which have been retired and are not included in NetAdvantage 11.2. I would suggest that you replace them with their new equivalents - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.2/CLR4.0/html/Classic_Control_Migration_Guide.html. Alternatively, you could use their versionless assemblies – more information can be found in the following article - http://blogs.infragistics.com/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx.
If you have any further questions, please do not hesitate to ask.
I,m use the Version Upgrade Utility to upgrade my projects.But Many Control Can't Upgrade success for the Log File:
3:24:52: C:\FEM_ST\ClassTree.aspx has been backed up.03:24:52: Upgraded register directive Infragistics2.WebUI.UltraWebNavigator.v9.2 to Infragistics2.WebUI.UltraWebNavigator.v9.2.03:24:52: C:\FEM_ST\Dashboard.aspx has been backed up.03:24:53: Upgraded register directive Infragistics2.WebUI.UltraWebGrid.v9.2 to Infragistics2.WebUI.UltraWebGrid.v9.2.03:24:53: C:\FEM_ST\left.aspx has been backed up.03:24:53: Upgraded register directive Infragistics2.WebUI.UltraWebListbar.v9.2 to Infragistics2.WebUI.UltraWebListbar.v9.2.03:24:53: Upgraded register directive Infragistics2.WebUI.UltraWebNavigator.v9.2 to Infragistics2.WebUI.UltraWebNavigator.v9.2.03:24:53: C:\FEM_ST\left2.aspx has been backed up.03:24:53: Upgraded register directive Infragistics2.WebUI.UltraWebListbar.v9.2 to Infragistics2.WebUI.UltraWebListbar.v9.2.03:24:53: Upgraded register directive Infragistics2.WebUI.UltraWebNavigator.v9.2 to Infragistics2.WebUI.UltraWebNavigator.v9.2.03:24:53: C:\FEM_ST\licenses.licx has been backed up.03:24:53: C:\FEM_ST\LoginPage.aspx has been backed up.03:24:53: Upgraded register directive Infragistics2.WebUI.WebDataInput.v11.2 to Infragistics2.WebUI.WebDataInput.v11.2.
I would suggest that you use the Version Upgrade Utility to upgrade your projects. Here is the documentation and a step-by-step description of how to use the utility - http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Web_Using_Version_Upgrade_Utility.html.
If you have any further questions, please let me know.
