We are using infragistics ultrawebgrid and grouping and expanding functionality .We have large data .For large data e.row.Expanded(true) is giving long running javascript error .So we implemented javascript function .But is there any property so by deafult column should come expanded instead of collapse,so we can atleast avoid calling javascript on page load. Please let me know any property.
Hello,Please let me know if you have any further questions regarding this issue.
Hello Sharma,What do you mean by column content are overlapping=hidden? Currently only WebTab has overlapping property http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebTab_Overlapping_Tabs.html Is it possible for you to attach a small archive with template grid which illustrates what issue you are facing and what you are trying to achieve?
I am using TableLayout=auto and colWidthdeafult='' to autosize column width based on content and remove all width from the columns and column content are overlapping=hidden . Some of the values are hidden and columns width are not adjusting based on content.I am missing someother propertly.
What is the proper way to adjust column based on content.
There is a limitation of our controls described in our documentation in Remarks paragraph:http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Infragistics4.WebUI.UltraWebGrid.v11.1~Infragistics.WebUI.UltraWebGrid.UltraGridLayout~TableLayout.htmlWhen TableLayout is Auto it is not able to use fixed headers or Margines.
I am using infragistics 10.3 ultrawebgrid .
