Is there a known issue with the Outline levels in the solution? For some reason certains rows are not grouped properly or with another level than one I specified. For example:
For each object1 in list1
For each object2 in list2
for each object3 in list3
OutlineLevel 1
Next
OutlineLevel 2
Outline level 3
Outline Level 4
In certain iterations an Outline level 2 will end up with a row from outline level 3
Maybe I'm going at it the wrong way. Can someone provide any help?
I am just following up to see if you need any assistance with this matter. If this issue is still present, provide me with more details as Mike asked above so I may look in to this.
Can you post a code snippet which produces results you are not expecting? I am not sure what you are expecting or what you are seeing and how they differ.
