I am using Infragistics4.WebUI.UltraWebChart.v11.2I am using a composite chartI want both the x and y values to be displayed in the tooltip.Y Axis is of type Numeric X Axis is of type TimeFollowing is the code that I am using.ultraChart.Tooltips.Format = Infragistics.UltraChart.Shared.Styles.TooltipStyle.Custom;ultraChart.Tooltips.FormatString = "<DATA_VALUE:0.##> @ <ITEM_LABEL>";Ideally following is the output that I want to see1093.22 @ 04/08i.e. (y axis value @ x axis value).But the above code gives only the y axis value i.e. (1093.22 @)
Please Help ASAP.Thanks, Utkarsh Bandekar
Problem Solved..I used the followingclass CustomToolTips : IRenderLabel{ public string ToString(System.Collections.Hashtable context) { return context["DATA_VALUE"].ToString() + "@" + ((System.DateTime)context["TIME_VALUE"]).ToString("MM/dd/yyyy HH:mm:ss"); }}Hashtable myHashTable = new Hashtable();myHashTable.Add("MyLabel", new CustomToolTips());ultraChart.LabelHash = myHashTable;ultraChart.Tooltips.Format = Infragistics.UltraChart.Shared.Styles.TooltipStyle.Custom;ultraChart.Tooltips.FormatString = "<MyLabel>";
