I am using WebDataMenu as context menu. I am able to render the menu on right click of mouse on a WebDataTree node from client side. How ever I need to disable some of the menu items based on the level of the node on which we right click and the configuration for that particular level ( which will be known only at run time) .
Can anyone tell me how to similarly render the menu from server side on right click of mouse? As it is easy for me to achieve it from server side.
Hi nancy1985,
Please let me know if you need further assistance with the matter.
It seems to me that there is no method to display the menu in context mode from code behind. You could render two separate menus with the items you need and display the appropriate menu depending on the clicked node's level.
If you have any questions, please do not hesitate to ask.
