I am trying to upgrade my web application from v10.3 to v11.2 and facing lot of issues.
The following are the errors that i have got after trying to upgrade using version utility.
Error 2 The type 'Infragistics.WebUI.Shared.IProvideAppStyling' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Shared.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error 3 The type 'Infragistics.WebUI.Shared.ISmartCallbackRender' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Shared.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error 4 The type 'Infragistics.WebUI.Util.Serialization.ISupportPresetSerialization' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Shared.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error 5 The type 'Infragistics.WebUI.Design.IGetClientSideEvents' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Shared.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
Error 6 The type 'Infragistics.WebUI.Shared.IUltraLicensedComponent' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Shared.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
also, pl advise why some of the dlls in the attached are not upgraded to v11.2 . I guess some of them are retired and kindly suggest solution please.
Parthiban
Hello Parthiban,
If you need any further assistance with the matter, please let me know.
Hi Parthiban,
I suggest that you try to add the required references manually after removing the old references - http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.2/CLR2.0/html/Win_Upgrading_a_Project_Manually.html. You can find the retired controls and their replacements here - http://blogs.infragistics.com/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx.
