3760
Dynamically created template not associated to item
Is there some sample code available for creating a WebExplorerBar template, group and item dynamically? Or hopefully, I am missing something simple?I had this working when configured in the markup but I need to create them dynamically. Although the code runs and I can access the webdatatree from within the template, a call to WebExplorerBar1.group(0).item(0).FindControl("TemplateTest") does not return an object and even when I add nodes to webdatatree in the template, they do not show. I has hoping that as long as the templateid for the item matched the templateid of the template then they would be associated (as happens in the markup) but this is not happening. The below example code is being tested in the page_load.
        Dim newGroup As New ExplorerBarGroup
        Dim newItem As New ExplorerBarItem
        newGroup = New ExplorerBarGroup
        newGroup.Text = "Group Text"
        newGroup.Value = "Group Value"
        newItem = New ExplorerBarItem
        newItem.TemplateId = "TemplateTest"
        newGroup.Items.Add(newItem)
        WebExplorerBar1.Groups.Add(newGroup)
        Dim ExplorerBarTemplate As New ItemTemplate
        Dim wdt As New Infragistics.Web.UI.NavigationControls.WebDataTree
        wdt.ID = "Test Tree"
        ExplorerBarTemplate.ID = "Template ExplorerBar"
        ExplorerBarTemplate.TemplateID = "TemplateTest"
        ExplorerBarTemplate.Controls.Add(wdt)
        WebExplorerBar1.Templates.Add(ExplorerBarTemplate)
