1025
Word Automation with Infragistic
Ms Word is used in my project for reports so we create the Word document and upload that document In the database in the form of Text sream to use it further to create the report.
this part is working perfactly ok on IIS, Now when we create the report we have to read that text Stream
change some tags with original data and then send it to client this was done thru word automation and everything was working ok on local machine but when i deploy it on the IIS it does not work>as Microsoft does not support Automation on IIS.
I was looking for infragistics document library and got Infragistic word document , Can i create the document from the stream i have saved in the Database and can travel thru the document and change the data in the infragistic document.
If u can provide any document that will be a great help
Note - we can change the methods by which we are uploading the word template in the database if required.
