I am Using WebHierarchicalDataGrid v 11.2. I need to display amount according to the local currency setting and also the currency symbol. It can be achieved by binding CurrencyEditorProvider to the column I suppose. Though I am not sure about it.
How to add currency control to the grids child band column? Please help me with this.
Amruta
Hello Maya,
Thanks a lot for the reply. That is what exactly I wanted. In my grid it is fine even if there is no currency symbol while editing a cell. But it should show in the entire column when in non-editable mode.
DataFormatString property worked for me.
Hello AmrutaDeshpande ,
You can add the CurrencyEditorProvider to a certain column by following these steps:
1. Add it to the EditorProviders collection of the grid.
2. In the behaviors’s collection of the specific band under the cell editing behavior add EditingColumnSetting and set the ColumnKey to the key of the column and the EditorID to the id of the CurrencyEditorProvider. For example:
<ig:CellEditing>
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="Data" EditorID="currencyEd1" />
</ColumnSettings>
</ig:CellEditing>
Keep in mind that the formatting of the currency provider will be applied only when you’re in editing mode of the cell. To set the formatting of the column when it’s not in editing mode you’ll need to set the column's DataFormatString property.
Let me know if you have any questions or if you need further assistance.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
http://www.infragistics.com/support
