Hi I'm having trouble with the AppStylist for ASP.NET. There are certain controls that do not display at all in the preview canvas:
I have had this problem for some time, with various versions of Infragistics (Currently 11.2). I'm assuming this is an issues with the browser control used to display the controls (SHDocVw.dll) and that since I'm not seeing anyone else complaining about this that it will have something to do with my configuration of internet explorer or that there is something missing on my PC.
I'd appreciate it if someone could give me some pointers as to what the possible causes of this issue are.
I only have version 11.2 installed at the moment. When I run the appstylist with the /debug commandline switch I receive the following error messages
I am facing the same problem. The web controls like WebDataGrid, WebDataMenu etc donot display in the preview canvas. I am using VisualBasis 2012, Windows7 and NetAdvantage AppStylist v12.2 Version 12.2.20122.2014. I have also installed ASP.NET Ajax 1.0 ASPAJAXExtSetup.msi.
Hello ,
I submited this behaviors in our internal tracking system so our developers can investigate this further. I have created for you a separate private support tickets so you can follow up on the progress of the issues. This way you will be automatically notified when the resolution for this is available.
@ lauramicale I created for you a support ticket with number CAS-99231-L9J7G1 and I have linked it issue 119975
@ jptrahan I created for you a support ticket CAS-99232-Y0B3V4 and I have linked it with issue 119976.
I will provide you with more details on the matter through your support tickets.
Please let me know if you need any additional information on this.
+1 on having this issue. I get a bunch of jscript errors and when I try to view some of the controls all I see is javascript code
I also have the same issue. Windows 7 X64 SP1. IE9.
Normal 0 21 false false false EN-US X-NONE X-NONE
Hi Dr_Tone,
This was resolved afterIntegraXP reinstall his OS.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
http://es.infragistics.com/support
