Do you have any sample project using ultrawebchart(column) and chart can drill down? I found the sample code in help document but only part of the code I need the project that I can see all the code.
Hello Madhukar,I have opened a support ticket with id - CAS-102167-B6H1Z9 regarding the issue. We will continue our communication through it. You can observe it by logging in our website going to accounts -> Support Activity -> Active tickets
Thank you for contacting Infragistics developer support. I am attaching a working sample based on our online help tutorial - http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Chart_WebChart_Set_Up_Drilldown_Charts.html . Please take a look at it and modify your code based on it. Sample was tested with IE 9
