155
javascript Error onSelectedDayChanged
Hey Guys!
Ive created a UserControl with your Calendar.
Worked fine .. but since this morning .. (i dont know why) i'll get always an error, if ill change my selected day .. same if i'll change the month..
Error: "old is undefined"
in: _setBackState: function (key, val)
Row: 353
Cant figure out, why ill get this error ..
I've tried, if it is something with the ViewState .. but I've not set any in this UserControl!
So if i click on one day, it doesnt jump in the DayChanged function.
My Code for the DayChanged function:
protected void DateChanged(object sender, CalendarSelectedDateChangedEventArgs e)
this.selectedDates = ((WebMonthCalendar)sender).SelectedDates.IndividualDates;
if (this.SelectedDayChanged != null)
this.SelectedDayChanged(sender, e);
((WebMonthCalendar)sender).SelectedDate = DateTime.Today;
Thanks for any solutions !
  • 155
    Okay .. now ive found out the line of code:
        function beforeSelectionChange(calendar, args) {
            var dates = args.get_dates();
            var range = args.get_range();
            if ((!range || range.length < 2) && dates && dates.length == 1)
                return;
            var evt = args.get_browserEvent();
            if (!evt || evt.ctrlKey || evt.shiftKey || evt.type != 'mousedown') {
                args.set_cancel(true);
                return;
            var target = evt.target;
            if (!target)
                target = evt.srcElement;
            var css = target ? target.className : null;
            if (!css || css.indexOf('_WeekNumber') < 0) {
                return;
    there it goes in this _setBackState function and throw me this javascript error ...
    hope it helps!
