I've a gird with several child grids.
One of the grids has the details and is always expanded, and I'd like to hide the selector column.
Is there a way to do that?
Thanks, knew the answer was simple.
Hello Charles,If I understand you correctly you have enabled row selectors and all you have to do is to enter in the behaviors of the current band and disable row selectors.
Like usual, found the answer as soon as I sent the text.
<ig:Band DataKeyFields="ParcelID" DataMember="DetailsSqlDataSource_DefaultView" AutoGenerateColumns="false" Key="DetailsSqlDataSource_DefaultView" showHeader="False" ItemCssClass="Textboxes" ExpansionColumnCss="displayNone" >
Set the ExpansionColumnCss to a css class with the Display set to None.
Hides the column.
Now only have to find out how to remove the padding around the border.
