935
How to add Rownumbering of Child Bands in Manual on Load Demand
I add this on my Code but it doesnt work : Async Failed
        // Create Container Grid
            ContainerGrid childGrid = new ContainerGrid();
            childGrid.InitializeRow += Child_InitializeeRow;
            e.Row.RowIslands.Add(childGrid);
            // Bind Grid
            childGrid.DataKeyFields = "ChildId";
            childGrid.Level = 1;
            childGrid.DataSource = first;
            childGrid.DataBind();
             childGrid.Behaviors.RowSelectors.RowNumbering = true; //<---I need to enable this one when my child row initializes
Thanks in Regards
  • 49378
    Hi NewbApps,
    In order to add the RowSelectors behavior when manually loading data, you would first need to first add the behavior on the root band (the behavior itself can be disabled however it should be defined). Subsequently, in your RowIslandsPopulating handler you can enable RowSelectors and RowNumbering on your child grid using:
             RowSelectors selectorBehavior = child.Behaviors.CreateBehavior<RowSelectors>();
            selectorBehavior.Enabled = true;
            selectorBehavior.RowNumbering = true;
           child.DataBind();
    Please let me know if this helps.
  • 49378
    Verified Answer
    Hi NewbApps,
           child.DataBind();
