745
BIG Problem : WebDropDown inside WebDialogWindow v11.2
Hi there.
I have this issue:
I'm using infragistics 11.2 version and I have a webdropdown with some items populated. Here is the code in html:
ig:WebDropDown ID="ddlFornecedorInfo" runat="server" TextField="Descricao" ValueField="ID" Width="205px"></ig:WebDropDown>
If I put this on my aspx page it works fine. I select an item from the bottom of the list and everything works fine.
But if I put the SAME dropdown on a webdialog window I have a problem. When I try to select an item from the bottom of the list, the scroll of the dropdown always moves to top of the list and I can't select the item.
Please help.
Thank you
