I have created a webpage to display the UltraChart whose ChartType is "StackSplineAreaChart". When I assign a datasource to a chart it displays the correct result but When I hover my mouse on particular point to see the Data_Value it shows the wrong count.
Here is my aspx page
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Temp.aspx.vb" Inherits="Temp" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title></title></head><body> <form id="form1" runat="server"> <div> <igchart:UltraChart ID="ucStackedSplineAreaChartForMonth" runat="server" EnableCrossHair="False" BackColor="White" EmptyChartText="Data Not Available. " ChartType="StackSplineAreaChart" Version="6.3" Width="470px" Height="280px" Border-Thickness="0"> <TitleLeft Location="Left" Extent="33" Visible="True" Text="" HorizontalAlign="Center"> </TitleLeft> <TitleTop Text="" HorizontalAlign="Center"> </TitleTop> <ColorModel ModelStyle="CustomLinear" AlphaLevel="150"> </ColorModel> <Effects> <Effects> <igchartprop:GradientEffect Style="forwarddiagonal"> </igchartprop:GradientEffect> </Effects> </Effects> <Axis> <X2 Visible="false" LineThickness="1" TickmarkStyle="Smart" TickmarkInterval="0"> <Labels ItemFormatString="<ITEM_LABEL>" VerticalAlign="Center" Visible="False" HorizontalAlign="Far" Font="Verdana, 7pt" FontColor="Gray" Orientation="VerticalLeftFacing"> <SeriesLabels VerticalAlign="Center" HorizontalAlign="Center" Font="Verdana, 7pt" FontColor="Gray" Orientation="VerticalLeftFacing"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> <MajorGridLines AlphaLevel="255" DrawStyle="Dot" Color="Gainsboro" Visible="True" Thickness="1"></MajorGridLines> <MinorGridLines AlphaLevel="255" DrawStyle="Dot" Color="LightGray" Visible="False" Thickness="1"></MinorGridLines> </X2> <Z Visible="False" LineThickness="1" TickmarkStyle="Smart" TickmarkInterval="0"> <Labels ItemFormatString="" VerticalAlign="Center" Visible="False" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="DimGray" Orientation="Horizontal"> <SeriesLabels VerticalAlign="Center" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="DimGray" Orientation="Horizontal"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> <MajorGridLines AlphaLevel="255" DrawStyle="Dot" Color="Gainsboro" Visible="True" Thickness="1"></MajorGridLines> <MinorGridLines AlphaLevel="255" DrawStyle="Dot" Color="LightGray" Visible="False" Thickness="1"></MinorGridLines> </Z> <Z2 Visible="False" LineThickness="1" TickmarkStyle="Smart" TickmarkInterval="0"> <Labels ItemFormatString="" VerticalAlign="Center" Visible="False" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="Gray" Orientation="Horizontal"> <SeriesLabels VerticalAlign="Center" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="Gray" Orientation="Horizontal"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> <MajorGridLines AlphaLevel="255" DrawStyle="Dot" Color="Gainsboro" Visible="True" Thickness="1"></MajorGridLines> <MinorGridLines AlphaLevel="255" DrawStyle="Dot" Color="LightGray" Visible="False" Thickness="1"></MinorGridLines> </Z2> <X LineThickness="1" Extent="130" TickmarkStyle="Smart" TickmarkInterval="0"> <Labels ItemFormatString="<ITEM_LABEL>" VerticalAlign="Center" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="DimGray" Orientation="VerticalLeftFacing"> <SeriesLabels VerticalAlign="Center" HorizontalAlign="Center" Font="Verdana, 7pt" FontColor="DimGray" Orientation="VerticalRightFacing" Visible="true"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> <MajorGridLines AlphaLevel="255" DrawStyle="Dot" Color="Gainsboro" Visible="True" Thickness="1"></MajorGridLines> <MinorGridLines AlphaLevel="255" DrawStyle="Dot" Color="LightGray" Visible="False" Thickness="1"></MinorGridLines> </X> <Y Visible="True" TickmarkInterval="20" LineThickness="1" Extent="25" TickmarkStyle="Smart"> <Labels ItemFormatString="<DATA_VALUE:00.##>" VerticalAlign="Center" HorizontalAlign="Far" Font="Verdana, 7pt" FontColor="DimGray" Orientation="Horizontal"> <SeriesLabels VerticalAlign="Center" HorizontalAlign="Far" Font="Verdana, 7pt" FontColor="DimGray" Orientation="VerticalLeftFacing" FormatString=""> </SeriesLabels> <Layout Behavior="UseCollection"> </Layout> </Labels> <MajorGridLines AlphaLevel="255" DrawStyle="Dot" Color="Gainsboro" Visible="True" Thickness="1"></MajorGridLines> <MinorGridLines AlphaLevel="255" DrawStyle="Dot" Color="LightGray" Visible="False" Thickness="1"></MinorGridLines> </Y> <Y2 Visible="False" TickmarkInterval="5" LineThickness="1" TickmarkStyle="Smart"> <Labels ItemFormatString="<DATA_VALUE:00.##>" VerticalAlign="Center" Visible="False" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="Gray" Orientation="Horizontal"> <SeriesLabels VerticalAlign="Center" HorizontalAlign="Near" Font="Verdana, 7pt" FontColor="Gray" Orientation="VerticalLeftFacing" FormatString=""> <Layout Behavior="Auto"> </Layout> </SeriesLabels> <Layout Behavior="Auto"> </Layout> </Labels> <MajorGridLines AlphaLevel="255" DrawStyle="Dot" Color="Gainsboro" Visible="True" Thickness="1"></MajorGridLines> <MinorGridLines AlphaLevel="255" DrawStyle="Dot" Color="LightGray" Visible="False" Thickness="1"></MinorGridLines> </Y2> <PE ElementType="None" Fill="Cornsilk"></PE> </Axis> <DeploymentScenario ImageURL="ChartImages/Chart_E_#SEQNUM(100).png" /> <TitleRight Location="Right" Extent="0" Visible="True"> </TitleRight> <Legend Visible="True" Location="Right" SpanPercentage="40"></Legend> </igchart:UltraChart> </div> </form></body></html>
Here is my aspx.vb code
Partial Class Temp Inherits System.Web.UI.Page Protected Sub Page_Load(sender As Object, e As System.EventArgs) Handles Me.Load Try Dim dt As New DataTable Dim dc As New DataColumn Dim dr As DataRow dc = New DataColumn dc.ColumnName = "Stock Name" dc.DataType = Type.GetType("System.String") dt.Columns.Add(dc) dc = New DataColumn dc.ColumnName = "Monday" dc.DataType = Type.GetType("System.Int32") dt.Columns.Add(dc) dc = New DataColumn dc.ColumnName = "Tuesday" dc.DataType = Type.GetType("System.String") dt.Columns.Add(dc) dc = New DataColumn dc.ColumnName = "Wednesday" dc.DataType = Type.GetType("System.String") dt.Columns.Add(dc) dr = dt.NewRow() dr("Stock Name") = "IBM" dr("Monday") = 111 dr("Tuesday") = 96 dr("Wednesday") = 85 dt.Rows.Add(dr) dr = dt.NewRow() dr("Stock Name") = "MSN" dr("Monday") = 111 dr("Tuesday") = 23 dr("Wednesday") = 15 dt.Rows.Add(dr) dr = dt.NewRow() dr("Stock Name") = "MCI" dr("Monday") = 55 dr("Tuesday") = 63 dr("Wednesday") = 84 dt.Rows.Add(dr) ucStackedSplineAreaChartForMonth.DataSource = dt ucStackedSplineAreaChartForMonth.DataBind() Catch ex As Exception End Try End SubEnd Class
When I run the webpage and see the tooptip data of "Monday" for "IBM","MSN" and "MCI" it displays the data 111,222 and 277 respectively. Instead of that It should display 111,111 and 53.
As per my thought a StackSplineAreaChart display is adding the values and display the data.
Please let me know If I am doing anything wrong? Please reply me ASAP.
Hello,Please let me know if you need further assistance with this case. Is the issue still persisting?
Hello Anil,Please let me know what is your exact build of NetAdvantage and what browser you are using for test. I will create a sample based on your code and examine it to see what could be causing the issue.
