210
Incorrect Formulas on loading an Infragistics excel
I am currently using Infragistics4.WebUI.Excel.v10.3 version 10.3.20103.1013 and I am facing an issue with formulas in the cell.
If there is a column with has different formula in the individual cells then the concern arises.
I have a excel file which has formulas in a column and the formulas for each cell in the column are different.
When I load the same excel file the values in the first 2 cells are as per the formula whereas from the third row the formula is getting set as the formula of the second row which is resulting in wrong values. Please note that I have seen a similar issue in Windows Section.
Do let me know if there is a workaround for the same.
Thanks and Regards,
Ritesh
  • 44743
    This sounds like the same as issue 62014, which was fixed in versions 10.1 and later, but after the RTM version of 10.3 (10.3.20103.1013) was released. So I think you should be able to fix this by upgrading to the latest SR for 10.3. If that doesn't fix the issue, let me know.
