285
Bug in setting value of UnboundCheckBoxField from code-behind?
I have an issue when setting the value of an UnboundCheckBoxField from code-behind. Here is some sample code:
Markup:
<%@ Page Language="C#" AutoEventWireup="false" CodeBehind="Default.aspx.cs" Inherits="UnboundCheckBoxFields._Default" %>
<%@ Register Assembly="Infragistics35.Web.v11.2, Version=11.2.20112.1019, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server">
    <div>
        <ig:WebScriptManager ID="WebScriptManager1" runat="server">
        </ig:WebScriptManager>
        <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px" AutoGenerateColumns="false">
            <Columns>
                <ig:UnboundCheckBoxField Key="Check" ></ig:UnboundCheckBoxField>
                <ig:BoundDataField Key="Value" DataFieldName="BoundFieldName" ></ig:BoundDataField>
            </Columns>
        </ig:WebDataGrid>
    </div>
    <asp:Button ID="btnPostBack" runat="server" />
    </form>
</body>
</html>
Code-behind:
public partial class _Default : System.Web.UI.Page
        protected override void OnInit(EventArgs e)
            base.OnInit(e);
            Load += Page_Load;
        protected void Page_Load(object sender, EventArgs e)
            if (!IsPostBack)
                List<MyClass> list = new List<MyClass>();
                for (int i = 0; i < 10; i++)
                    list.Add(new MyClass(i));
                WebDataGrid1.DataSource = list;
                WebDataGrid1.DataBind();
                foreach (GridRecord gridRecord in WebDataGrid1.Rows)
                    gridRecord.Items[0].Value = Convert.ToInt32(gridRecord.Items[1].Text) % 2 == 0;
    public class MyClass
        public int BoundFieldName { get; set; }
        public MyClass(int boundFieldValue)
            BoundFieldName = boundFieldValue;
The rows with values 0,2,4,6,8 are checked, but doing postback by clicking the button removes all rows from the grid. If I set EnableDataViewState to true the data is displayed after postback, but no rows are checked, neither on initial load nor after postback.
Is there another way to solve this?
I am using version 11.2.20112.1019.
