I use WHDG, to display 1 child band.
On my web page the grid is ok.
But when I export it to excel (WebExcelexporter), all by child rows are duplicated.
version 10.3
Thx
Hello dufour01 ,
Thank you for the sample code.
Using it I was able to reproduce the behavior. The issue happens because you are initializing the hierarchical data source too late in PageLoad event handler.
I recommend you using Init event handler of WebHierarchicalDataSource for the purpose.
I am attaching a sample code using NorthWind database which I have not included in order to reduce the size of the file.
Please let me know if you have further questions.
Tried without my linq query, same problem.
WebHierarchicalDataSource1.DataViews.FindByID("TableA").DataSource = Data.Tables["TableA"]; WebHierarchicalDataSource1.DataViews.FindByID("TableB").DataSource = Data.Tables["TableB"];
No problem with the sample for me
I just upgraded to lattest version with latest patch. Same problem.
I attached an test.
display of webpage is good, but export duplicate child bands.
Totest : 2 tables to create :
TableA and TableB with Fields A1, A2 and fields B1,B2
B1 is a foreign key to A1
Thank you for posting in our forums.
Can you please share what build of v10.3 you are using?
I was not able to reproduce the issue with the online samples of v11.2
http://samples.infragistics.com/aspnet/Samples/WebHierarchicalDataGrid/Data/ExcelExport/Default.aspx?cn=excel-exporter&sid=fc0d912a-3031-4146-b53c-2d5d9fde9a58
Would you be able to provide an isolated sample reproducing the issue (or at least the markup and code behind of the page)?
Hope hearing from you
