I used to use UltraWebGrid and have got it working successfully with database side paging and sorting. But now i am trying WebDataGrid and I could not achieve same functionality with this new grid.
I want to fetch only 10 records from database which are chosen based on pagination and are already sorted. End user won't know if I am fetching only 10 records each time from database. He would see normal sorting functinlity and paging functionlity on user interface.
Can someone help me to understand how i can achieve same functionality with WebDataGrid?
Vikas
Hi Vikas,
If you have any further questions on that matter please do not hesitate to ask.
The behavior you have described seems to be the default for WebDataGrid when sorting and paging are enabled. Demonstrative samples of these features can be found at the following links - http://samples.infragistics.com/aspnet/Samples/WebDataGrid/Navigation/Paging-Basic-Features/Default.aspx?cn=data-grid&sid=cfd4524a-2692-4d06-a825-a90fff70c261
http://samples.infragistics.com/aspnet/Samples/WebDataGrid/Editing-and-Selection/All-Behaviors-Enabled/Default.aspx?cn=data-grid&sid=d71789d5-590a-4c98-8c54-3b5aa010fe85
Please let me know if this helps.
