Hi all,
I currently use Infragistics Version=11.1.2011.2116.
How do I set the serialization flag in code behind for the following?
Type 'Infragistics.Web.UI.GridControls.GroupedColumns' in Assembly 'Infragistics4.Web.v11.1, Version=11.1.20111.2116, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' is not marked as serializable.
Unfortunately documentation in this regard is greatly lacking.
Tom
Hello Tom,
Did you try to resize the column sizes prior to persist them? Also, please enable the resizing behavior like this:
Behaviors>
Resize some columns when page is loaded and try again to persist the columns collection.
Ivan
Hello Ivan,
I have tried your sample code, but the column width is always empty. Whether I specify the columns from the grid or the grid.grid view - as below.
Other property data is however persisted - so I am not sure why the widths are not persisted.
Private Sub PersistenceSaved()
Dim manager As Persistence.PersistenceManager = Persistence.PersistenceManager.GetInstance()
Dim behaviorData As Persistence.ControlData = manager.SaveControl(Me.whdgDefault1.Behaviors, "gridBehaviours")
_gridSettings.PersistedBehaviors = behaviorData.ToXml()
Dim columnData As Persistence.ControlData = manager.SaveControl(Me.whdgDefault1.GridView.Columns, "gridColumns")
_gridSettings.PersistedColumns = columnData.ToXml()
End Sub
The columns are initialized before the Persistence sub is called - during the grid.initializeband event.
Any other ideas?
--Tom
if you want to persist the Column on the Root level you can call:
PersistenceManager
manager = PersistenceManager.GetInstance();
ControlData
data = manager.SaveControl(WebHierarchicalDataGrid1.Columns,
"WebHierarchicalDataGrid1Columns");
If you want to persist the Columns of the first sub-band you can call:
data = manager.SaveControl(WebHierarchicalDataGrid1.Bands[0].Columns, "WebHierarchicalDataGrid1Columns");
Have in mind, that the columns should be defined either in code behind or in the markup of the page. If columns are auto generated this approach would not work.
Hello Ivan & co.,
Thank you for the information. This was very helpful.
I am however still not able to fully persist the grid column layout data.
Is there an example you can point me too, to achieve this.
I am specifically interested in the column widths as I would like to persist this information between user sessions.
Yes, you can persist a particular peaces of the grid. Let say you want to persist the WebHierarchicalDataGrid's Behaviors property. All you need to do is:
//Persisting:
PersistenceManager manager = PersistenceManager.GetInstance();
ControlData data = manager.SaveControl(this.WebHierarchicalDataGrid1.Behaviors, "WebHierarchicalDataGrid1Behaviours");
string xml = data.ToXml(); //save this xml somewhere
//Restoring:
ControlData data2 = ControlData.FromXml(xml);
manager.LoadControl(this.WebHierarchicalDataGrid1.Behaviors, data2);
