I am using Web context menu to show some items. The menu is shown just before the right corner of the screen. So some part of menu text is not visible. This is because the menu is always shown to the right of mouse pointer. Can we have the context menu to display on the left side of the pointer when there is not enough space on the right side.
Please let me know how to resolve this.
Thanks in advance.
Hello Maya,
Thanks for the reply.
Unfortunately I can't use additem/removeitem as they make AJAX calls and so response will be slower than pure client side. And setting fixed width will make certain items wrap or have too much gap for smaller text items.
So I am still trying how to go about this.
Thanks a lot.
Hello sandy_joggy,
Let me know if i can further assist you in any way.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
http://es.infragistics.com/support
It seems that with this approach changing the width once it gets set is not an option. If you use the methods removeItem and addItem resizing issues do not occur.
I can only suggest that you wrap the text and set a width for the menu items so that the longer text won’t change the width.
For example set the CssClass of the ItemSettings to the following css class:
.ItemClass
width: 100px !important;
overflow: visible;
white-space: normal;
You can also further modify the menu item setting by setting :
oMenu._element.runtimeStyle.textAlign = "right";
So that the text will be displayed on the right side (since you mentioned that in your scenario the menu will open on the left side of the pointer).
Refer to the attached sample and let me know if this would be an acceptable solution for your scenario. If not I’d advise you to use the functions that were meant for adding and deleting items.
Let me know if I can be of further assistance.
Hi Maya,
Thanks a lot for the reply!. It sure moves the issue forward.
So now we are saving the menu width the first time and using it to show menu right or left of the mouse pointer. It works very well except in one case. Initially suppose menu had 2 items and one item was very lengthy. Now later that lenthy item is removed(hidden). Now menu has just the one short item, but menu is shown to far left from the pointer - because it is using the initial menu width. I am always right-clicking at the right end of screen.
So the issue is that since we are storing the initial width, when menu shrinks in size, menu will be shown to far left from the pointer using the initial stored width.
Please find attached sample page having a "Remove" button to illustrate the issue.
Hello sandy_joggy ,
I apologize about the late reply.
It seems that this is connected to the IsContextMenu property which hides the menu. What I’ve notice however is that once the Menu shows the first time it’s width doesn’t seem to change.
Note the sample I’ve attached. Click on add say 4 times to have 4 items in the menu and right click on the image. It will show the four items horizontally aligned. Now click on add four more times to add 4 more item and notice that when you open the menu the items are 4x4 vertically aligned. So in this case I think you might need only the initial width to calculate where on the page you should display the context menu. Please refer to the attached sample and let me know if this solution would be applicable in your scenario.
