Hey there
I'm trying to put a WebUpload control on my aspx page however I've run into a brick wall. I keep getting this error when I access the page on which the control is on.
With Firebug...
I've been scouring the net for a solution but come up with nothing. I'm aware that usually when this happens the jscript/css file haven't been loaded but I have them there and referenced.
I've tried inserting them in manually and using the WebUpload Task panel to add the files. Both of which were unsuccessful.
Could I please get some assistance on this?
Below is my code using the WebUpload Task panel to add the files.
<%@ Page Language="VB" AutoEventWireup="false" Inherits="FMI.WSMplannet.Web.System_AddDocument" Codebehind="AddDocument.aspx.vb" %>
<%@ Register Assembly="Infragistics35.Web.jQuery.v11.1, Version=11.1.20111.2064, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI.EditorControls" TagPrefix="ig" %>
<%@ Register assembly="System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" namespace="System.Web.UI" tagprefix="cc1" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<link rel="stylesheet" type="text/css" href="../css/WSMplannet.css" />
<link rel="stylesheet" type="text/css" href="../css/Custom.css" />
<title>Add Standard Document</title>
<style type="text/css">
.style1
width: 100%;
</style>
<script src="../ig_ui/js/min/ig.ui.upload.min.js" type="text/javascript" id="igClientScript"></script>
</head>
<body>
<link id="link1" href="../ig_ui/themes/ig/jquery.ui.custom.min.css"
rel="Stylesheet" type="text/css" />
<link id="link2" href="../ig_ui/themes/base/ig.ui.min.css" rel="Stylesheet"
type="text/css" />
<form id="form1" runat="server">
<div>
<asp:Literal ID="litMessage" runat="server"></asp:Literal><br />
<table style="width: 660px">
<tr>
<td class="bglabel" style="width: 100px">
<br />
<asp:Label ID="Label1" runat="server" Text="1. Select document to add..." Width="227px"></asp:Label></td>
</tr>
<td style="width: 100px">
<asp:Label ID="Label3" runat="server" BackColor="White" Font-Bold="False" ForeColor="Black"
Text="Note: Maximum file size = 4MB." Width="374px"></asp:Label><br />
<asp:Label ID="Label4" runat="server" BackColor="White" Font-Bold="False" ForeColor="Black"
Text="Warning: Depending on your connection speed, large files may take a long time to upload or even time out."
Width="642px"></asp:Label></td>
<asp:FileUpload ID="file" runat="server" Height="19px" Width="615px" />
<asp:RequiredFieldValidator ID="RequiredFieldValidator2" runat="server" ControlToValidate="file"
ErrorMessage="Please select file to upload" ValidationGroup="valGroup">*</asp:RequiredFieldValidator><br />
</td>
<td>
<ig:webupload runat="server"></ig:webupload>
<asp:Label ID="Label2" runat="server" Text="2. Enter description..." Width="205px"></asp:Label></td>
<asp:TextBox ID="txtDescription" runat="server" Width="334px"></asp:TextBox><asp:RequiredFieldValidator ID="RequiredFieldValidator1" runat="server" ControlToValidate="txtDescription"
ErrorMessage="Please enter description of document" ValidationGroup="valGroup">*</asp:RequiredFieldValidator></td>
<td style="width: 100px; height: 62px;">
<asp:ValidationSummary ID="ValidationSummary1" runat="server" ValidationGroup="valGroup"
Width="338px" />
<table >
<asp:Button ID="btnSave" runat="server" Text="Save" ValidationGroup="valGroup" Width="65px" />
<asp:Button ID="btnCancel" runat="server" Text="Cancel"
Width="65px" />
</table>
</div>
</form>
</body>
</html>
Awesome! Works like a charm.
Thanks for that!
Hello Raylodge,
Try changing the order of the scripts to the below and see if that resolves the issue.
<script src="../scripts/jquery-1.4.4.min.js" type="text/javascript" id="Script2"></script>
<script src="../scripts/jquery-ui.min.js" type="text/javascript" id="Script3"></script>
<script src="../ig_ui/js/min/ig.ui.min.js" type="text/javascript" id="Script1"></script>
Please let me know if you have any further questions regarding this matter.
Thanks a lot for you help. Sorry about that. I had tried the below scripts/css files as well with no success.
Firebug seems to think the error is generating from the ig.ui.min.js file.
Is there something else that I need to do besides just adding the files in their respective folders and reference them in my aspx page?
Thank you for the details provided. I don’t see the below JavaScript files referencing anywhere in the code you have provided. You need to have these files referenced in your project in order for Webupload control to work properly. Please include them and see if that resolves the issue
jquery-1.4.4.min.js
jquery-ui.min.js
ig.ui.min.js
Please let me know if I can provide any further assistance regarding this matter.
Sincerely,
Prabha.
