I've noticed that the spell checker control doesn't scroll properly to the misspelled words when they are located in a table (and possibly other areas)
I've made changes to your ig_spellcheckerdialog.js file and i was hoping you would put this change into your next patch so i don't have to remember to make the change again next time i upgrade. I'm currently using 2011.1
just rename the attached file back to ig_spellcheckerdialog.js.patch
Hello Greg,
This issue has been addressed by our Development team and is now fixed in the latest Service Release for versions 11.1 and 11.2 - builds 2158 and 2055.
You can see our latest service releases in our web site - “Support > Service Releases” and download them from “My IG > My Keys and Downloads” page.
Thank you for choosing Infragistics.
I have logged this behavior in our issue tracking system with ID – 97378.
I will post in this thread when fix is available.
Thank you.
i didn't actually submit it as a request i had only just put it on the forum... so i just now submitted it CaseNumber=CAS-79084-T0FG6K
Hello gregrhind,
I have checked the source code for version 11.1 and I can confirm that the change made by you is not included there.
Changes to the Source Code of our controls that will be included in the future versions can only be made from our Development Team and after verification and approval from our QA and Test teams.
Every other modification made outside of this process is not supported officially.
Did you logged the described by you behavior as development issue?
If yes, can you give me the number of this issue (or of the support case) in order to let me check its status?
