340
Upgrade NA 2008 v.1 to NA 2011 v.1
Hello!
I am using UltraWebGrid of Infragistics 2008. I upgrade NA 2008 v.1 to NA 2011 v.1 in my application  not with version utility but manually. I remove all of the references of NA 2008 from application and assemblies from GAC. I remove all of the things from licence file. i upgrade the web.config file.
But still getting the issue regarding UltraWebGrid. The errors are as follows:
The type 'Infragistics.WebUI.UltraWebGrid.UltraWebGrid' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.UltraWebGrid.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
and
Cannot implicitly convert type 'Infragistics.WebUI.UltraWebGrid.UltraWebGrid [c:\WINDOWS\assembly\GAC_MSIL\Infragistics35.WebUI.UltraWebGrid.v11.1\11.1.20111.1006__7dd5c3163f2cd0cb\Infragistics35.WebUI.UltraWebGrid.v11.1.dll]' to 'Infragistics.WebUI.UltraWebGrid.UltraWebGrid []'
Please help me if anyone has found the solution.
Regards
Asjad
