The asp.net help installs, but doesn't work. I get the error "Can't find requested content on your computer".
I have uninstalled/reinstalled. It won't work.
Hello cyberplasm,
Can you tell me what installer package do you use and from where did you downloaded it?
If your installation package is the correct one and the installation was completed successfully - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.2/CLR4.0/HTML/Web_NetAdvantage_Web_Client_ASPNET.html - you should perform the steps described in the following two guides:
http://community.infragistics.com/blogs/tom_puglisi/archive/2010/05/05/introducing-netadvantage-help-for-microsoft-visual-studio-2010.aspx
http://blogs.infragistics.com/blogs/tom_puglisi/archive/2010/05/04/installing-visual-studio-2010-help-for-netadvantage-windows-forms-and-asp-net-products.aspx
Inform me if you have additional questions.
It has to be manually installed into help. :+<
