[IndexOutOfRangeException: Index was outside the bounds of the array.] Infragistics.Web.UI.GridControls.GridBot.LoadClientCollections(Object[] collections) +341 Infragistics.Web.UI.Framework.RunBot.LoadClientData() +88 Infragistics.Web.UI.Framework.RunBot.HandleLoadPostData(String postDataKey, NameValueCollection postCollection) +41 Infragistics.Web.UI.GridControls.GridBot.HandleLoadPostData(String postDataKey, NameValueCollection postCollection) +82 Infragistics.Web.UI.GridControls.ContainerGrid.LoadPostData(String postDataKey, NameValueCollection postCollection) +90 System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) +690 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1743
I am getting the above exception using 11.1 . I was able to update a test project to 11.2 and in that project the error stopped happening.
Unfortunately I use UltrawebGrid and so cannot currently update to 11.2 .
Hello nickhoare,
I am just following up to see if you need any further assistance with exception you mentioned above.
If this issue is still present, please provide me with details like NetAdvantage version of product you are using along with relevant markup and code used so I may look in to this.
By looking at the exception provided, I am not certain about the cause of this issue. As such, please provide me with details like NetAdvantage version of product you are using along with relevant markup and code used so I may look in to this.
