225
Pasting Text is not working?
    Previously we have been using Infragistics 2006 Vol 3 version. Now we have purchased Infragistics 2001 Vol 1. I have updated our project to the latest version. I have a webhtml editor in the page, i have added a right-click option to the editor. I have the options "Cut", "Copy", "Paste" and "Paste as HTML". When we click on "Paste", it should paste without any extra tags. When we click on "Paste as HTML", it will paste the text with the existing formats. The problem that i face is, When i right-click on the control and click on paste, first it's ask a question "Do you want to allow this webpage to access your Clipboard?". I click on "Allow Access", and it paste the text. By default, after pasting the text the right-click event should get disappeared, but it doesn't happen.
Now i click on "Save", in the server side, it is saying there is no value. If after pasting, i just click on the editor, the menu then gets disappeared and then i click on "Save" button without typing any text. In the server-side, now i am able to see the text value.
 But when i right-click and select "Paste as HTML", then the menu gets disappeared and on clicking on "Save" button, i am able to see the text value in server-side. I am puzzled by this behaviour. I have attached the image and also the code for it. Please tell me is there a problem with my code?
<script id="igClientScript" type="text/javascript">
var ctrl = false;
var v = false;
function HtmlEditorKeyDown(oEditor, keyCode, oEvent)
     if(keyCode == 17)
        ctrl = true;
   if(keyCode == 86)
        v = true;
   if(ctrl == true && v == true)
        var text;
        if(window.clipboardData.getData("Text")!= null && window.clipboardData.getData("Text")!= "")
            text = window.clipboardData.getData("Text");
        PasteFromClipboard();
        oEvent.cancel = true;
        return false;
function UpdateEditor()
   var evnt = window.event;
   x = evnt.keyCode;
   if(x == 17)
       ctrl = false;
   if(x == 86)
       v = false;
   var edit = iged_getById("<%=WMS_txtBox.ClientID%>");
   edit._update();
function CutToClipboard()
   CutTxt = document.selection.createRange();
   CutTxt.execCommand("Cut");
   document.getElementById("<%=WMS_txtBox.ClientID%>").focus();
function WebHtmlEditor1_AfterAction(oEditor, actID, oEvent)
  oEditor._update();
function CopyToClipboard()
   CopiedTxt = document.selection.createRange();
   CopiedTxt.execCommand("Copy");
function PasteFromClipboard()
  edit.focus();
     insertAtCursor(edit, window.clipboardData.getData("Text"));
function insertAtCursor(myField, myValue)
//IE support
    if (document.selection)
        myField.focus();
        sel = document.selection.createRange();
        sel.text = myValue;
    //MOZILLA/NETSCAPE support
    else if (myField.selectionStart || myField.selectionStart == '0') {
        var startPos = myField.selectionStart;
        var endPos = myField.selectionEnd;
        myField.value = myField.value.substring(0, startPos)
        + myValue
        + myField.value.substring(endPos, myField.value.length);
    } else
        myField.value += myValue;
function EnableSpellCheck()
        var keyCode = event.keyCode;
        if ((keyCode == 32 || keyCode == 31) && document.getElementById("<%=btnSpellCheck.ClientID%>").value == "")
            document.getElementById("<%=btnSpellCheck.ClientID%>").disabled=true;
        else
            document.getElementById("<%=btnSpellCheck.ClientID%>").disabled=false;
      return true;
    function callSpellCheck()
        var editor = ig_getWebControlById("<%=WebSpellChecker1.ClientID%>");
        if (editor == null)
            alert('Spell Checker Component was not found!');
            return;
       var edit = iged_getById("<%=WMS_txtBox.ClientID%>").ID;
       editor.checkTextComponent(edit);
function wbtnSoundRecorder_Click(id)
    IsDT = "<%=Session["IsDT"]%>";
    if(IsDT == "True")
       if(document.getElementById("DeliveryControl1_hdnSoundRecorder") != null)
         document.getElementById("DeliveryControl1_hdnSoundRecorder").value = iged_getById("<%=WMS_txtBox.ClientID%>").ID;
       if(document.getElementById("MFODeliveryControl1_hdnSoundRecorder") != null)
         document.getElementById("MFODeliveryControl1_hdnSoundRecorder").value = iged_getById("<%=WMS_txtBox.ClientID%>").ID;
         var url ="http://SoundRecorder";
         window.open(url,'PopUpWindow','','');
function replaceAll(text, strA, strB)
    while ( text.indexOf(strA) != -1)
        text = text.replace(strA,strB);
    return text;
function getWMS_txtBoxText()
   var editor = iged_getById('<%= WMS_txtBox.ClientID %>');
   if (!editor) return "";
   if (editor._ie) return editor._elem.innerText;
   if (editor._body().innerText) return editor._body().innerText;
   return editor._body().textContent;
function setWMS_txtBoxText(text)
    edit.setText(text);
function setWMS_txtBoxFocus()
function wbtnScreenRecorder_Click()
    //Add code to handle your event here.
    if(IsDT == "True")
         var url ="ScreenRecorder";
function btnTemplate_Click(oButton, oEvent)
    igmenu_showMenu('UltraWebMenuTemplate', event,(getElementPosition('btnTemplate').left)-120,(getElementPosition('btnTemplate').top)+10);
    oEvent.cancel=true;
    oEvent.cancelPostBack=true;
    this.CancelPostBack=true;
function UltraWebMenuTemplate_ItemClick(menuId, itemId)
    var item = igmenu_getItemById(itemId);
    alert(item.getTag());
    if(item != null && item != 'undefined')
        var text = item.getTag();
        if(text.indexOf(':') > 0)
            text = text.substring(text.indexOf(':')+2);
        var menu = igmenu_getMenuById(menuId);
        if(text != "Exit Menu")
            insertAtCursor(document.getElementById("<%=WMS_txtBox.ClientID%>"), text);
            menu.CancelPostBack = true;
        else
function getElementPosition(elemID)
    var offsetTrail = document.getElementById("<%=btnTemplate.ClientID%>");
    var offsetLeft = 0;
    var offsetTop = 0;
    while (offsetTrail)
        offsetLeft += offsetTrail.offsetLeft;
        offsetTop += offsetTrail.offsetTop;
        offsetTrail = offsetTrail.offsetParent;
    return { left: offsetLeft, top: offsetTop };
function WebSpellChecker1_BeforeSpellCheckBegins(oWebSpellChecker, oEvent, uncheckedText)
function getDelDesc(name)
     var editor = iged_getById(name);
</script>
<table style="height:98%;width:100%;border-bottom:solid 1px #759DB9;border-top:solid 1px #759DB9;border-left:solid 1px #759DB9;border-right:solid 1px #759DB9" cellpadding="0" cellspacing="0">
<tr id="trButton" runat="server" visible="false" >
<td width="100%" height="25px" align="left" id="tdTextBoxCtrl" runat="server" >
<table style="height:25px; width:100%;" cellpadding="0" cellspacing="0" align="left">
<tr align="left" >
<td>
<BUTTON id="btnCut" tabIndex="1" type="button" onClick="CutToClipboard()" runat="server" style="border:0px;cursor:hand;background-color:Transparent;" title="Cut"><img  runat="server" id="imgCut"/></BUTTON>
</td>
<td style="height:20px;padding-left:8px">
<BUTTON id="btnCopy" tabIndex="1" type="button" onClick="CopyToClipboard()" runat="server" style="border:0px;cursor:hand;background-color:Transparent;" title="Copy"><img  runat="server" id="imgCopy"/></BUTTON>
</td>
<BUTTON id="btnPaste" tabIndex="1" type="button" onClick="PasteFromClipboard()" runat="server" style="border:0px;cursor:hand;background-color:Transparent;" title="Paste"><img  runat="server" id="imgPaste"/></BUTTON>
</td>
<td style="height:20px;padding-left:8px;padding-right:8px;background-color:Transparent;" align="right" runat="server" id="tdSep3">
<asp:Panel runat="server" ID="Panel2" Width="1px"></asp:Panel>
</td>
<td width="16px" align="right"  >
<igtxt:WebImageButton ID="wbtnScreenRecorder" SkinID="CCEWebPrev" runat="server" Text="" UseBrowserDefaults="False" Height="16px" Width="16px" ToolTip ="Screen Recorder" >
        <ClientSideEvents Click="wbtnScreenRecorder_Click" />
</igtxt:WebImageButton>
</td>
<td style="height:20px;padding-left:8px;padding-right:8px;background-color:Transparent;" align="right" runat="server" id="tdSep2">
<asp:Panel runat="server" ID="Panel1" Width="1px"></asp:Panel>
</td>
<td  align="right">
   <BUTTON id="btnSpellCheck" tabIndex="1" type="button" runat="server" style="border:0px;cursor:hand;background-color:Transparent;" title="Check Spelling"><img  runat="server" id="imgBtn"/></BUTTON>
</td>
<td style="height:20px;padding-left:8px;padding-right:8px" align="right" runat="server" id="tdSep1">
<asp:Panel runat="server" ID="pnlsep" Width="1px"></asp:Panel>
</td>
   <td width="16px" align="right" style="padding-right:8px">
<igtxt:WebImageButton ID="wbtnSoundRecorder" SkinID="CCEWebNext" runat="server" Text="" UseBrowserDefaults="False" Height="16px" Width="16px" ToolTip ="Sound Recorder" >
   <ClientSideEvents Click="wbtnSoundRecorder_Click" />
</td>
<td>
<igtxt:WebImageButton ID="btnTemplate" SkinID="CCETemplateBtn" runat="server" Text="Insert from template" UseBrowserDefaults="False" Height="16px" ToolTip ="Click here to select templates" Visible="false" >
   <ClientSideEvents Click="btnTemplate_Click" />
</td>
<td width="100%" >
    </td>
</tr>
</table>
</td>
</tr>
<tr style="height:98%;">
<td style="width:100%;height:98%;word-break:normal;word-wrap: break-word">
 <ighedit:WebHtmlEditor ID="WMS_txtBox" Width="100%" EnableViewState="true" Focus="false"  Height="100%"  SkinID = "CCEWebHtmlEditor"   runat="server" TabStripDisplay="False" SpellCheckerID="WebSpellChecker1" UseLineBreak="true" FontFormattingList="Heading 1=<h1>&Heading 2=<h2>&Heading 3=<h3>&Heading 4=<h4>&Heading 5=<h5>&Normal=<p>"  FontNameList="Arial,Verdana,Tahoma,Courier New,Georgia" FontSizeList="1,2,3,4,5,6,7" FontStyleList="Blue Underline=color:blue;text-decoration:underline;&Red Bold=color:red;font-weight:bold;&ALL CAPS=text-transform:uppercase;&all lowercase=text-transform:lowercase;&Reset=" SpecialCharacterList="&#937;,&#931;,&#916;,&#934;,&#915;,&#936;,&#928;,&#920;,&#926;,&#923;,&#958;,&#956;,&#951;,&#966;,&#969;,&#949;,&#952;,&#948;,&#950;,&#968;,&#946;,&#960;,&#963;,&szlig;,&thorn;,&THORN;,&#402,&#1046;,&#1064;,&#1070;,&#1071;,&#1078;,&#1092;,&#1096;,&#1102;,&#1103;,&#12362;,&#12354;,&#32117;,&AElig;,&Aring;,&Ccedil;,&ETH;,&Ntilde;,&Ouml;,&aelig;,&aring;,&atilde;,&ccedil;,&eth;,&euml;,&ntilde;,&cent;,&pound;,&curren;,&yen;,&#8470;,&#153;,&copy;,&reg;,&#151;,@,&#149;,&iexcl;,&#14;,&#8592;,&#8593;,&#8594;,&#8595;,&#8596;,&#8597;,&#8598;,&#8599;,&#8600;,&#8601;,&#18;,&brvbar;,&sect;,&uml;,&ordf;,&not;,&macr;,&para;,&deg;,&plusmn;,&laquo;,&raquo;,&middot;,&cedil;,&ordm;,&sup1;,&sup2;,&sup3;,&frac14;,&frac12;,&frac34;,&iquest;,&times;,&divide;" StartupMode="Design">
            <Toolbar Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False"
                Font-Underline="False" CssClass="HideToolbar" BackgroundImage="" Height="25">
                <ighedit:ToolbarDropDown Type="FontName" Height="18" Width="30" UseAdvancedDisplay="true" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/dropdown.gif"  MouseDownImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/dropdown_down.gif"  MouseOverImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/dropdown_over.gif" >
                </ighedit:ToolbarDropDown>
                                    <ighedit:ToolbarDropDown Type="FontSize" Height="18" Width="30" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/dropdown.gif"  MouseDownImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/dropdown_down.gif"  MouseOverImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/dropdown_over.gif">
                   <ighedit:ToolbarImage runat="server" Font-Bold="False" Font-Italic="False" Font-Overline="False"
                    Font-Strikeout="False" Font-Underline="False" Type="Separator" Key="Img5" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Separator.gif" />
                <ighedit:ToolbarButton runat="server" Font-Bold="False" CssClass="toolbar"  Font-Italic="False" Font-Overline="False"
                    Font-Strikeout="False" Font-Underline="False" Type="Bold"  ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Bold.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="Italic" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Italic.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="Underline"  ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Underline.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="Separator" Key="Img2" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Separator.gif" />
                <ighedit:ToolbarButton runat="server" Font-Bold="False" Font-Italic="False" Font-Overline="False"
                    Font-Strikeout="False" Font-Underline="False" Type="Cut" CssClass="toolbar" onClick="CutToClipboard()" ImageName="./App_Themes/CCEPLXGNewStyles/Images/Cut.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="Copy" CssClass="toolbar" onClick="CopyToClipboard()" ImageName="./App_Themes/CCEPLXGNewStyles/Images/Copy.gif"/>
                    Font-Strikeout="False" Font-Underline="False" Type="Custom" ToolTip="Paste" Key="PastePlain" onclick="PasteFromClipboard()" CssClass="toolbar" ImageName="./App_Themes/CCEPLXGNewStyles/Images/Paste.gif"/>
                    Font-Strikeout="False" Font-Underline="False" Type="Separator" Key="Img1"  ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Separator.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="SpellCheck" CssClass="toolbar" ImageName="./App_Themes/CCEPLXGNewStyles/Images/SpellCheck.gif">
                </ighedit:ToolbarButton>
                <ighedit:ToolbarButton runat="server" Font-Bold="False" Font-Italic="False" Font-Overline="False" Key="Sound"
                    Font-Strikeout="False"  Font-Underline="False" Type="Custom" ToolTip="Sound Recorder" CssClass="toolbar"  onClick="wbtnSoundRecorder_Click(id)" ImageName="./App_Themes/CCEPLXGNewStyles/Images/SoundRec.gif">
                    Font-Strikeout="False" Font-Underline="False" Type="Separator"  Key="Img3" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Separator.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="JustifyLeft" CssClass="toolbar" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/JustifyLeft.gif" />
                    Font-Strikeout="False" Font-Underline="False" Type="JustifyCenter" CssClass="toolbar"  ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/JustifyCenter.gif"/>
                    Font-Strikeout="False" Font-Underline="False" Type="JustifyRight" CssClass="toolbar" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/JustifyRight.gif"/>
                    Font-Strikeout="False" Font-Underline="False" Type="JustifyFull" CssClass="toolbar" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/JustifyFull.gif"/>
                    Font-Strikeout="False" Font-Underline="False" Type="Separator"   Key="Img4" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Separator.gif"/>
                     <ighedit:ToolbarDialogButton Type="FontColor" CssClass="toolbar"  ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/FontColor.gif">
                        <Dialog Strings=""></Dialog>
                    </ighedit:ToolbarDialogButton>
                    <ighedit:ToolbarDialogButton Type="FontHighlight"  CssClass="toolbar1" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/FontHighlight.gif">
             </Toolbar>
         <ClientSideEvents KeyDown="HtmlEditorKeyDown" AfterAction="WebHtmlEditor1_AfterAction"/>
            <ProgressBar Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False"
                Font-Underline="False" />
            <DownlevelTextArea Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False"
             <RightClickMenu  >
                   <ighedit:HtmlBoxMenuItem runat="server" Act="Cut" Font-Bold="False" Font-Italic="False"
            Font-Overline="False" Font-Strikeout="False" Font-Underline="False" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Cut.gif">
              </ighedit:HtmlBoxMenuItem>
        <ighedit:HtmlBoxMenuItem runat="server" Act="Copy" Font-Bold="False" Font-Italic="False"
            Font-Overline="False" Font-Strikeout="False" Font-Underline="False" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Copy.gif">
          <ighedit:HtmlBoxMenuItem runat="server" Text="Paste" onmouseover='this.style.backgroundColor="#C1D2EE"' onmouseout='this.style.backgroundColor="#FFFFFF"' onclick="PasteFromClipboard();" CssClass="paste" Font-Bold="False" Font-Italic="False"
            Font-Overline="False" Font-Strikeout="False" Font-Underline="False" ImageName="./App_Themes/CCEPLXGNewStyles/Images/HtmlEditor1/Paste.gif">
        <ighedit:HtmlBoxMenuItem runat="server" Act="Paste" Text="Paste As Html" Font-Bold="False" Font-Italic="False"
            </RightClickMenu>
            <TextWindow Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False"
                Font-Underline="False" BorderWidth="0"   />
            <DownlevelLabel Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False"
            <TabStrip Font-Bold="False" Font-Italic="False" Font-Overline="False" Font-Strikeout="False"
        </ighedit:WebHtmlEditor>
</td>
</tr>
</table>
<div>
<ig_spell:WebSpellChecker ID="WebSpellChecker1" runat="server"  EnableViewState="False">
    <DialogOptions ShowNoErrorsMessage="True" />
    <ClientEvents BeforeSpellCheckBegins="WebSpellChecker1_BeforeSpellCheckBegins" />
    </ig_spell:WebSpellChecker>
</div>
Thanks and Regards,
S.Rajagopalan.
