1405
Change the size of Splitter Pane dynamically
I have a WebSplitter with two vertical splitterpanes. I want to collapse the first pane and also increase the size of second pane to 100% width. I have a datalist inside the second splitter pane and on collapsing the first pane the size of datalist along with the second pane should be increased to width 100%. Can anyone help me on how to do this on client side.
  • 19693
    Suggested Answer
    Hello mmegha ,
    Thank you for posting in our forums.
    I recommend you handling the Collapsed client side event.
    You can get the width of the second pane and set it to the datalist
    function WebSplitter1_Collapsed(sender, eventArgs)
           ///<summary>
           ///</summary>
           ///<param name="sender" type="Infragistics.Web.UI.WebSplitter"></param>
           ///<param name="eventArgs" type="Infragistics.Web.UI.SplitterCollapsedStateEventArgs"></param>
        //Add code to handle your event here.
        var size = eventArgs.get_affectedPane().get_size();
    Also please make sure that you have set  EnableRelativeLayout="true"
    Let me know if you need further assistance.
