I'm evaluating the infragistics ASP.NET 2011 V1 controls for our new project.
Using Windows 7 and VS2010 I'm trying to hook up a Access2000 database to the WebHierarchicalDataGrid.
However, when I click on the grid and set the DataSourceID to WebHierarchicalDataSource1 I get an error.
It first asks if I'd like to regenerate the WebHierarchicalDataGrid bands, I say YES.
Then I get a "Error setting property 'DataSourceID' to value WebHierachicalDataSource1'. Details: The control collection cannot be modified during DataBind, Init, Load, PreRender or Unload phases."
I press the OK button on the error box to close it.
Looking at the properties for the grid I see that the DataSourceID is set, but the DataMember and DataKeyFields are NOT set.
When I display the web page the data shows up as expected.
However, the biggest issue I have is that when I look at the band collection there is only one item, the RootBand. If I click on the Columns collection in this RootBand there are no WebDataGrid columns.
How do I fix the error that is showing up?
How do I edit the appearance of a column in a particular band if there are no bands being created?
I also tried to refresh the schema, and it gives me a different error: "Error invoking 'Refresh Schema'. Details: Exception has been thrown by the target of an invocation.
Yes, the issue I was having went away in 11.2
Hello Brian,Please confirm that the issue is resolved with NetAdvantage 11.2.20112.1019.
I updated to 2011.2 and the issues went away. They said they were working on a hot fix for 2011.1 and it would be released soon.
A month without a reply from anyone? Did you get it sorted out at all? I've run into the same thing.
