75
Crystal Reports and WebDataMenu conflicting
I am trying to use the WebDataMenu (11.1, i have also intalled the service release to see if this fixes the problem 11.1.20111.2064) with the crystalreportsviewer 13.0.2000 with not much success (VS.NET2010/VB).
basically if i have the webdatamenu after the crystalreportsviewer section both display correctly, but having the menu above the crystalreportsviewer (where i actually want it) causes the crystalreportsviewer to not display anything.
I have tested this on IE8,IE9,Firefox 7, this problem also applies to other infragistics controols such as webexplorerbar, webdatatree.
I can recreate this issue in a sample project as follows, this causes the report to not show, but moving the code for the datamenu after the reportviewer is ok.
<%@ Page Title="" Language="vb" AutoEventWireup="false" MasterPageFile="~/Site.Master" CodeBehind="WebForm1.aspx.vb" Inherits="WebApplication1.WebForm1" %>
<%@ Register assembly="Infragistics4.Web.v11.1, Version=11.1.20111.2064, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.NavigationControls" tagprefix="ig" %>
<%@ Register assembly="CrystalDecisions.Web, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692fbea5521e1304" namespace="CrystalDecisions.Web" tagprefix="CR" %>
<%@ Register assembly="Infragistics4.Web.v11.1, Version=11.1.20111.2064, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI" tagprefix="ig" %>
<asp:Content ID="Content1" ContentPlaceHolderID="HeadContent" runat="server">
</asp:Content>
<asp:Content ID="Content2" ContentPlaceHolderID="MainContent" runat="server">
    <ig:WebDataMenu ID="WebDataMenu1" runat="server">
        <Items>
            <ig:DataMenuItem Text="Root Item">
            </ig:DataMenuItem>
        </Items>
    </ig:WebDataMenu>
    <ig:WebScriptManager ID="WebScriptManager1" runat="server">
    </ig:WebScriptManager>
    <CR:CrystalReportViewer ID="CrystalReportViewer1" runat="server"
        AutoDataBind="true" ReportSourceID="CrystalReportSource1" />
    <CR:CrystalReportSource ID="CrystalReportSource1" runat="server">
        <Report FileName="CrystalReport1.rpt">
        </Report>
    </CR:CrystalReportSource>
</asp:Content>
site.master is just the default created and the report is just a blank one for testing purposes.
Any help would be appreciated.
Bob
