Im new for Infragistics product.
I have created a new webapplication and tried to display a PIE chart with some hard coded values. Below is the code.
<igchart:UltraChart runat="server" ID="pieChart" BackColor="White" Height="150px" Width="200px" ChartType="PieChart3D" Transform3D-Scale="100" Transform3D-XRotation="7" Transform3D-YRotation="3" Transform3D-ZRotation="-55" > <Tooltips Display="MouseMove" BackColor="Yellow" BorderColor="Black" Format="Custom" FormatString=" <ITEM_LABEL>: <DATA_VALUE:0> " BorderThickness="0" Font-Names="Arial,Verdana,Helvetica,sans-serif" Font-Size="8" Padding="10" /> <Border DrawStyle="Solid" Raised="false" Color="White" Thickness="0" /> <DeploymentScenario Scenario="Session" /> <PieChart3D OthersCategoryPercent="0" PieThickness="9" RadiusFactor="129"> <Labels Visible="False" FormatString="" LeaderLinesVisible="False" BorderColor="White" /> </PieChart3D> <Axis> <PE ElementType="None" /> </Axis> </igchart:UltraChart>
And the CS code is
NumericSeries series = new NumericSeries(); pieChart.ChartType = ChartType.PieChart3D; series.Points.Add(new NumericDataPoint(10, "Up", false)); series.Points.Add(new NumericDataPoint(15, "Warning", false)); series.Points.Add(new NumericDataPoint(20, "Critical", false)); series.Points.Add(new NumericDataPoint(24, "Down", false)); series.Points.Add(new NumericDataPoint(15, "Unknown", false)); series.Points.Add(new NumericDataPoint(1, "Unreachable", false)); pieChart.Series.Add(series);
But the Pie is not getting displayed, while running the application, Please correct me where i did a mistake.
Venu
try removing this line:
