75
How to add a column containing a hyperlink?
This is more of a conceptual questions, rather than a coding question. I would like to double-check my approach to my current issue.
What I want to do:
  • I want to have a column in my grid that contains a button/image with a URL in the WebDataGrid
  • the URL contains a URL portion that is dependant on data in the current row
  • the button/image will also have a tooltip that contains row-specific data
My current approach
  • I believe that I need to use a Row Item Template for the column that contains the button
  • This template includes an <asp:HyperLink> control
  • The properties of this control (NavigationUrl, ImageUrl, etc.) will be set using template control binding
Complicating factor:
  • There are a list of things that are known only at runtime...not design-time
  • This list includes: 1) the number of these "button/link" columns 2) the button image
Because of this complicating factor, I believe that I need to be creating/adding the Row Item Template programmatically (rather than in markup). I am having some other issues with this (see http://community.infragistics.com/forums/p/60078/305112.aspx). However, my main questions in this post are these:
  • Is this approach (conceptually) the right way to go?
  • Is there a simpler way to do what I want to do?
Joel
  • 19693
    Verified Answer
    Hello Joel,
    Thank you for your interest in WebDataGrid.
    This approach is the right way to implement this requirements.
    I have replied to the other post.
    You can use the WebImageButton to implement the button image column:
        private class CustomItemTemplate : ITemplate
            #region ITemplate Members
            public void InstantiateIn(Control container)
                CheckBox chkBox = new CheckBox();
                chkBox.ID = "TemplateCheckBox";
                // Get the cell value from the DataItem
                chkBox.Checked = (bool)((DataRowView)((TemplateContainer)container).DataItem)["BoolColumn"];
                HyperLink link = new HyperLink();
                link.ID = "TemplateHyperLink";
                string dataValue = (string)((DataRowView)((TemplateContainer)container).DataItem)["Data"];
                link.NavigateUrl = string.Format("http://www.google.bg/search?q={0}", dataValue);
                link.Text = (string)((DataRowView)((TemplateContainer)container).DataItem)["Data"];
                WebImageButton imgBtn = new WebImageButton();
                imgBtn.ID = "TemplateWebImageButton";
                imgBtn.CommandArgument = (string)((DataRowView)((TemplateContainer)container).DataItem)["Item"];
                imgBtn.Appearance.Image.Url = "~/ig_res/Default/images/add_down.gif";
                container.Controls.Add(link);
                container.Controls.Add(chkBox);
                container.Controls.Add(imgBtn);
            #endregion
    Let me know if you need further assistance
