745
Urgent........How to add One more child band for SelfReferenced Hierarchical grid
Hi All,
I developed a webheirarchy grid using 2009.2 version which is a self referenced Heirarchy grid....but i want to display another child band  based on  the last grand child result..i did the coding upto self reference child bands...below shows the code
.aspx
<ig:WebHierarchicalDataGrid ID="whdg_process_repository" runat="server" AutoGenerateBands="false"
                                        AutoGenerateColumns="false" EnableViewState="false" Font-Size="Smaller" InitialDataBindDepth="-1"
                                        InitialExpandDepth="0" OnInitializeRow="whdg_process_repository_OnInitializeRow"
                                        Visible="true" Width="100%">
                                        <ExpandCollapseAnimation SlideCloseDirection="Auto" SlideCloseDuration="300" SlideOpenDirection="Auto"
                                            SlideOpenDuration="300" />
                                        <Columns>
                                            <ig:TemplateDataField Key="Id">
                                                <ItemTemplate>
                                                    <asp:HiddenField ID="HiddenFieldComplianceRep" runat="server" Value='<%# Eval("Id") %>' />
                                                </ItemTemplate>
                                            </ig:TemplateDataField>
                                            <ig:TemplateDataField Key="FrameWorkName">
                                                <Header Text="FrameWorkName" />
                                                <ItemTemplate>
                                                    <asp:Label ID="Label_FrameWorkName" runat="server" Text='<%# Eval("FrameWorkName") %>'
                                                        Width="250px"></asp:Label>
                                                </ItemTemplate>
                                            <ig:TemplateDataField Key="OpenFindings">
                                                <Header Text="OpenFindings" />
                                                <ItemTemplate>
                                                    <asp:Label ID="Label_OpenFindings" runat="server" Text="" Width="250px"></asp:Label>
                                                </ItemTemplate>
                                            <ig:TemplateDataField Key="ClosedFindings">
                                                <Header Text="ClosedFindings" />
                                                <ItemTemplate>
                                                    <asp:Label ID="Label_ClosedFindings" runat="server" Text="" Width="250px"></asp:Label>
                                                </ItemTemplate>
                                            <ig:TemplateDataField Key="Rating">
                                                <Header Text="Rating" />
                                                <ItemTemplate>
                                                    <asp:Label ID="Label_Rating" runat="server" Text="" Width="250px"></asp:Label>
                                                </ItemTemplate>
                                            <ig:TemplateDataField Key="AddControl">
                                                <Header Text="Add Control" />
                                                <ItemTemplate>
                                                    <asp:Button runat="server" ID="Button_AddControl" CssClass="submitSmallButton" Text="Add"
                                                        ToolTip="Add Control" CausesValidation="false"></asp:Button>
                                                </ItemTemplate>
                                        </Columns>
                                        <Bands>
                                            <ig:Band AutoGenerateColumns="false" IsSelfReference="true">
                                                <Columns>
                                                        <ItemTemplate>
                                                            <asp:HiddenField ID="HiddenFieldComplianceRepChild" runat="server" Value='<%# Eval("Id") %>' />
                                                        </ItemTemplate>
                                                     <ig:BoundDataField Header-Text="Type" />
                                                    <%-- <ig:BoundDataField CssClass="description" DataFieldName="Description"
                                                            Header-Text="Description" Key="description" Width="200px" />
                                                        <ig:BoundDataField DataFieldName="Type" Header-Text="Type" Key="type" />
                                                        <ig:BoundDataField CssClass="exported" DataFieldName="Exported" Header-Text="" Key="exported" />--%>
                                                </Columns>
                                            </ig:Band>
                                        </Bands>
                                    </ig:WebHierarchicalDataGrid>
.aspx.cs
 public void loadDatatoWHDGridProcessRep()
        DataSet ds = new DataSet();
        ds = new ComplianceReportBO().GetFrameWorkNames();
        if (ds.Tables[0].Rows.Count > 0)
            DataRelation rel = new DataRelation("ComplianceRep", ds.Tables["ComplianceRep"].Columns["Id"], ds.Tables["ComplianceRep"].Columns["parent_id"]);
            ds.Relations.Add(rel);
            // Set the table's primary key field
            ds.Tables["ComplianceRep"].PrimaryKey = new DataColumn[] { ds.Tables["ComplianceRep"].Columns["Id"] };
            this.whdg_process_repository.IsSelfReference = true;
            this.whdg_process_repository.MaxDataBindDepth = 2;
            this.whdg_process_repository.DataSource = ds;
            this.whdg_process_repository.DataMember = "ComplianceRep";
            this.whdg_process_repository.DataKeyFields = "Id";
            this.whdg_process_repository.DataBind();
Please suggest me hw can i do
