Got this just moments ago on a page that simply made the mistake of containing a WebChart control. I am now having to reset IIS to clear the error, as no users can access the website. (because I made the mistake of placing a WebChart control on the homepage dashboard).
Using 2011.1, .Net 4.0. This issue has been documented all the way back to version 2009, and I have reported it several times.
Can someone from IG please take ownership of this issue and find a solution?
Server Error in '/ACISANDIEGO' Application. Parameter is not valid. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.ArgumentException: Parameter is not valid.Source Error: The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:1. Add a "Debug=true" directive at the top of the file that generated the error. Example: <%@ Page Language="C#" Debug="true" %>or:2) Add the following section to the configuration file of your application:<configuration> <system.web> <compilation debug="true"/> </system.web></configuration>Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario. Stack Trace: [ArgumentException: Parameter is not valid.] System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format) +1161965 Infragistics.UltraChart.Render.ChartRender.CreateChartBitmap(Int32 width, Int32 height) +105 Infragistics.UltraChart.Render.ChartRender.RenderChart(SceneGraph scene, Size sceneSize, SizeF resolution) +125 Infragistics.UltraChart.Render.ChartRender.RenderChart(SceneGraph scene, Int32 sceneWidth, Int32 sceneHeight) +75 Infragistics.WebUI.UltraWebChart.UltraChart.Render(HtmlTextWriter output) +11900 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer) +10 Infragistics.WebUI.Misc.WebAsyncRefreshPanel.Render(HtmlTextWriter writer) +141 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +31 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 ASP.masterpage_35_master.__Renderform1(HtmlTextWriter __w, Control parameterContainer) +228 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +109 System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +173 System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +31 System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +53 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +40 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Page.Render(HtmlTextWriter writer) +29 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3060
Hello Rob,
Thanks for the update. I have provided this feedback to my team lead. Please feel free to update me if you need any further assistance in future.
Bhadresh,
I ended up giving up on the control and migrated to a competitor's chart control. It just took way to long to get this bug fixed, and I lost confidence in IG's ability to do so.
-Rob
I am just following up to see, if you have had a chance to test the issue you described with latest service release. If the issue is still present, update me so I may look in to this.
I have noticed this issue is addressed on latest service release of NetAdvantage 2010.3 and above version. You may download latest service release by logging in to your account on the below link:
<https://es.infragistics.com/Login.aspx?ReturnUrl=%2fMembership%2fDefault.aspx%3fpanel%3dDownloads&panel=Downloads>
Once you log in to your account, click on the version of NetAdvantage product you are using in NetAdvantage tab. In the "Service Releases" section click on the link for the appropriate version of NetAdvantage.
Update me if you need any further assistance.
Thank you very much!
