Can you please show how to code for a checkbox list in a RowEditTemplate...I'm using a Sql data source to populate checkbox list. Thx!
I have decided to use the checkboxlist because it works best for my solution. Thanks.
Hello davefevold ,
I'm following up to see if you might still need assistance with this approach. If so please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
http://es.infragistics.com/support
It would be very helpful if you could provide a sample with the issue represented so that I can further research this.
Maybe the issue is caused by the environment you’re running. Could you tell me which version of Infragistics controls you’re using, which OS you’re using and on which browsers and their versions you’ve encountered the issue. Also does the previously provided sample work as expected on your environment?
I’m looking forward to your reply.
Maya, I've tried following your example and other examples in the forum...still, I'm unable to make the control "Drop down". I may have to pursue other options.
I'm just following up to see if you need any further assisatnce with this issue. If so let me know.
