i have upgraded the Infragistics library with 2011.v1.1.
If we resize the column in webDataGrid then resizing give dragging action is undefined error.
it was working in my 2010.3 version.
Hi Mark,
According to the bug, the first build it was available was 11.1.20111.2050. So it will need to be a service release with a number higher than that. It looks as if it should be available in the next publicly available one.
-Dave
Has this Service Release been released yet? I see that there is a service release for ASP.Net 2011 vol 1., NetAdvantage_ASPNET_20111.2036_SR, but wasnt sure if this is the correct one?
Thanks david for faster response.
Hi Mypost,
That is exactly the bug I have mentioned. It is a bug that is only present when autopostback is set to true. If you turn that off, the grid will run fine. This bug has been fixed and is awaiting release in the September Service Release. If you require a build sooner, I would suggest contacting Developer Support.
Hi David,
Thanks for reply. i am using simple WebDataGrid.
I have AutoPostFlag set to true on resizing the column.
i am using 2011 v1.0 version. but problem is still there.
can you suggest me correct solution?
Thanks in advance.
