How do you run a function in a websplitter?
I have a function in the page that is loaded in Pane1.
I want to run that function when a user clicks a button in Pane 2, how do I accomplish this?
I have attached a small project to show what I am looking for.
Thanks for sharing with the community.
This is the fix that I got from Infragistics folks. The help documentation and response time are painfully low so I will post the answer.
var mainSplitter = parent.window.$find("WebSplitter1"); if (mainSplitter != null) { var panes = mainSplitter.get_panes(); var bodyPane = panes[0]; var resultVar = bodyPane.get_iframe(); var myFunctionResult= resultVar.contentWindow.MyFunction(); }
You need to call use "contentWindow" in order to access any functions from the other pane.
