I am upgrading infragistics from 2009 to 2011. my config file entries for 2009 infragistics in the web application are as follows.
Infragistics35.WebUI.Shared.v9.2, Version=9.2.20092.2099, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
How do i change my config entries to 2011.
Sheela
Hello Sheela,
I would recommend using the Version Utility that we provide.
Using the Version Utility
You can download the Version Utility here. It's the last link under "Products and Bundles".
The alternative is to manually upgrade. You would search for all "v9.2" and replace it with "v11.1". Then search for all "9.2.20092.2099" and replace it with "11.1.20111.1006" or whatever version you are upgrading to.
Elizabeth AlbertLocalization Engineer
