I am new to infragistics control,i am working on asp.net website.
It is the first time i use the WebDataGrid!
I just have noticed that the virtual scrolling on the WebDataGrid is causing a ERROR~
There was an error "Deserialization failure: Invalid response. " When i move the scrolling.
i dunna why~
Kandly help~THX~
Hi Yves,
Glad that you found the solution you needed.
Please let me know if you need more help with this matter.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
Found it!
The problem is, when the grid was performing the postback for filtering, sorting or paging, my user control in which the grid is hosted was set as non visible (Visible = false) from the main page. This was causing the PreRender and Render on my control to not being called and was giving me the issue.
Therefore, when your grid does the postback, make sure it is visible and the parent control is visible on the server side or the rendering methods won't be called thus getting the problem.
Yves
I forgot 2 things:
1 - I'm using IE8
2 - The working data list has 394 records and the one giving me the error has 124 records.
Hi, I do have the same problem with my datagrid and am using version 2010 Vol3. Refer to this post for my code: http://community.infragistics.com/forums/p/60820/310160.aspx#310160
What is interesting is that I load my grid with 2 different set of data: 1 is returning me the error when I sort (filter, etc.) on the second try, but not the other set of data. When seeing that, I assumed the problem was with my datasource objects that could have a serialization problem. I changed my object list to something simpler for my testing and I still get the same error.
I dynamically create my columns:
if (this.Parameters.ReportValues.ReportId == DeserializationFailureReport) { this.AddColumn("Number", "Number", String.Empty, 7, typeof(string)); this.AddColumn("Type", "Type", String.Empty, 9, typeof(string)); this.AddColumn("Date", "Time", "{0:dd/MM/yyyy HH:mm:ss}", 13, typeof(DateTime)); this.AddColumn("ErrorCode", "Code", String.Empty, 5, typeof(int)); this.AddColumn("ErrorDescription", "Error", String.Empty, 40, typeof(string)); this.AddColumn("Address", "Location", String.Empty, 22, typeof(string)); } else if (this.Parameters.ReportValues.ReportId == WorkingReport) { this.AddColumn("Number", "Number", String.Empty, 7, typeof(string)); this.AddColumn("ype", "Type", String.Empty, 9, typeof(string)); this.AddColumn("Start", "Start", "{0:dd/MM/yyyy HH:mm:ss}", 13, typeof(DateTime)); this.AddColumn("End", "Stop", "{0:dd/MM/yyyy HH:mm:ss}", 13, typeof(DateTime)); this.AddColumn("Distance", "Distance (Km)", "{0:#0.###}", 8, typeof(Decimal)); this.AddColumn("TimeInMinutes", "Time (hh:mm:ss)", "{0:hh\\:mm\\:ss}", 6, typeof(TimeSpan), new FormatRecordItemValue(FormatTimeSpan)); this.AddColumn("Qty1", "Qty1", "{0:#0.##}", 6, typeof(Decimal)); this.AddColumn("Qty2", "Qty2", "{0:#0.##}", 6, typeof(Decimal)); this.AddColumn("Qty3", "Qty3", "{0:#0.##}", 8, typeof(Decimal)); this.AddColumn("Qty4", "Qty4", "{0:#0.##}", 6, typeof(Decimal)); this.AddColumn("Qty5", "Qty5", "{0:#0.##}", 6, typeof(Decimal)); this.AddColumn("Qty6", "Qty6", "{0:#0.##}", 6, typeof(Decimal)); }}
for my testing, I gave the grid a List<Test> object and Test is defined as:
[Serializable] public class Test { private string _number; private string _type; private DateTime _date; private int _errorCode; private string _errorDescription; private string _address; private int _report;
public string Number { get { return _number; } set { _number = value; } }
public string Type { get { return _Type; } set { _Type = value; } }
public DateTime Date { get { return _date; } set { _date = value; } }
public int ErrorCode { get { return _errorCode; } set { _errorCode = value; } }
public string ErrorDescription { get { return _errorDescription; } set { _errorDescription = value; } }
public string Address { get { return _address; } set { _address = value; } }
public int Report { get { return _report; } set { _report = value; } }
I populate the list, then I call this:
this.reportDataIGGrd.ClearDataSource();this.reportDataIGGrd.DataKeyFields = "Report";this.reportDataIGGrd.DataSource = lst;this.reportDataIGGrd.DataBind();
In the page_load, I set the datasource back with the list when filtering, sorting or paging is done:
if (!String.IsNullOrEmpty(this.Request.Form["hdnGridAction"])){ this.reportDataIGGrd.DataSource = lst;}
Here's my grid in the aspx:
<asp:UpdatePanel ID="dataGridUpdPnl" runat="server" > <ContentTemplate> <input type="hidden" id="hdnGridAction" name="hdnGridAction" /> <ig:WebDataGrid ID="reportDataIGGrd" runat="server" AutoGenerateColumns="false" InitialExpandDepth="-1" EnableDataViewState="true" DataKeyFields="Report" EnableAjax="true" AjaxIndicator-Enabled="True" AjaxIndicator-BlockArea="Control" AjaxIndicator-BlockCssClass="ig_AjaxIndicatorBlock" Height="100%" Width="100%" InitialDataBindingDepth="-1" > <Columns> </Columns> <Behaviors> <ig:Activation Enabled="true" /> <ig:Selection RowSelectType="Multiple" CellClickAction="Row" Enabled="true" /> <ig:Sorting SortingMode="Single" Enabled="true" SortingClientEvents-ColumnSorting="SetGridAction" SortingClientEvents-ColumnSorted="ClearGridAction"/> <ig:Filtering Alignment="Top" Visibility="Visible" Enabled="true" AnimationEnabled="true" FilteringClientEvents-DataFiltering="SetGridAction" FilteringClientEvents-DataFiltered="ClearGridAction" /> <ig:Paging PagerAppearance="Both" PagerMode="NumericFirstLast" PagingClientEvents-PageIndexChanging="SetGridAction" PagingClientEvents-PageIndexChanged="ClearGridAction" QuickPages="3" PageSize='<%$ appSettings:PageSize_ReportDataMapGrid%>' FirstPageText="First" LastPageText="Last" > </ig:Paging> </Behaviors> <EmptyRowsTemplate> <div style="text-align: center;"> <br /> <br /> <img src="Images/information.gif" alt="!" align="middle" /> <asp:Label ID="noDataLabel" runat="server" Text="No records found." Font-Size="Small" ForeColor="#000099" Font-Bold="True"> </asp:Label> </div> </EmptyRowsTemplate> <ErrorTemplate> <div style="text-align: center; width: 800px;"> <img src="Images/error.png" alt="!" align="middle" /> <asp:Label ID="errorLabel" runat="server" Text="An error has occurred! Please contact support." Font-Size="Small" ForeColor="#CC0000" Font-Bold="True"> </asp:Label> </div> </ErrorTemplate> <ClientEvents Initialize="intializeGrid" /> </ig:WebDataGrid> </ContentTemplate> <Triggers> <asp:AsyncPostBackTrigger ControlID="btnClear" EventName="Click" /> </Triggers> </asp:UpdatePanel>
Hi EvenChen,
Please do not hesitate to contact me if you are still experiencing any issues.
