I want to write a javascript function check on the data grid change or add data.
There is no functional attributes such tests do not? (the same UpdateRowBatch in server)?
Thanks.
Hi nhungnt,
Are you talking about the WebDataGrid or UltraWebGrid. That event sounds like it is from the latter. If that is the case, you should post your question here. Currently, the WebDataGrid can only batch edit updates on the client. In 11.2, it will be able to batch adds and deletes as well.
regards,David Young
