I'm working with Infragistics3.Documents.Excel.v11.1 (version 11.1.20111.2009)How can I set the print area (Page Setup) with programing code: - The scaling of the print area (set at x%) - Adjust the number of pages per High - Margins (Top, Bottom, Left, Right, Footer) - Center on page (horizontal, vertical)Thank you in advance for your replay.
I believe you would control that with the Worksheet.PrintOptions.MaxPagesHorizontally and Worksheet.PrintOptions.MaxPagesVertically.
When I say 'Adjust the number of pages per High', I want mean: In Page Setup: Scaling Fit to x1 page(s) wide by x2 tall
All print options are stored on the Worksheet.PrintOptions.
ddol said:The scaling of the print area (set at x%)
Set the Worksheet.PrintOptions.ScalingType to UseScalingFactor
and the Worksheet.PrintOptions.ScalingFactor to a value from 10 to 400.
ddol said:Adjust the number of pages per High
I'm not sure what you mean by this? Could you elaborate. If you are referring to the number of copies, you can set the Worksheet.PrintOptions.NumberOfCopies.
ddol said:Margins (Top, Bottom, Left, Right, Footer)
Set the folllowing properties on Worksheet.PrintOptions: TopMargin, BottomMargin, LeftMerging, and RightMargin.
ddol said:Center on page (horizontal, vertical)
Set the following properties on Worksheet.PrintOptions: CenterHorizontally and CenterVertically.
