Why does the following not work?
In the InitializeRow for the grid, depending on status I need to set a template value.
For example I have the following line:
e.Row.Items(wdgPriceless.Columns.FromKey("STRIKE").Index).Text = "Strike"
The grid always shows an empty cell.
Here is the markup for the grid:
<ig:WebDataGrid ID="wdgPriceless" runat="server" AutoGenerateColumns="False" EnableAjax="False" EnableDataViewState="True" Visible="False"> <Columns> ... <ig:TemplateDataField Key="STRIKE" Width="25%"> <ItemTemplate> <asp:Label ID="wdg_lbl_Strike" runat="server" /> </ItemTemplate> <Header Text="Strike" /> </ig:TemplateDataField> ... </Columns> <Behaviors> <ig:Activation /> <ig:RowSelectors Enabled="true" /> <ig:Selection CellClickAction="Row" RowSelectType="Single"> <AutoPostBackFlags RowSelectionChanged="true" CellSelectionChanged="false" ColumnSelectionChanged="false" /> </ig:Selection> </Behaviors> </ig:WebDataGrid>
What I needed to do was the following:
Get the control from the templated field.
Dim lbl As Label = CType(e.Row.Items(wdgPriceless.Columns.FromKey("STRIKE").Index).FindControl("wdg_lbl_Strike"), Label)
lbl.text = "Strike"
