75
i can't obtain id of WebDialogWindow in Initialize event, windowstate is hidden
I have a WebDialogWindow which initial i don't want to be visible so i setted the windowstate property to hidden, i have a button when i press i want to open WebDialogWindow clientside using Click event of button with a handler similar with this:
function WebImageButton1_MouseDown(){var dialog = $find(wdwid);
dialog.show();
return false;
because i use master content page the ID wich i assigned to WebDialogWindow in designer is not the same with the id assigned by container in generated page onclient in consequence i can't use the ID assigned in designer to show window. I try to obtain and save the id of WebDialogWindow in Initialize event
var wdwID
function Initialize(sender, args){
wdwID = sender.get_id();
but this event is firred work only if the initial WindowState isn't Hidden, i have tried set initial WindowState = Normal and to hide it in Initialize event but you can observe how appear and dissapear the WebDialogWindow
Infragistics used
<%@ Register Assembly="Infragistics2.WebUI.Misc.v8.1, Version=8.1.20081.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.WebUI.Misc" TagPrefix="igmisc" %>
  • 28464
    Indeed, if the control is nested inside other controls implementing INamingContainer, such as MasterPages / User Controls / Templates, etc, the server-side ID is different from the client-side ID (ClientID). You need to use the client-side ID on the client with javascript, so you can use the following javascript construct:
    var dialog = $find(<%= wdwid.ClientID %>);
