Hi, I'm trying to write some code which inserts the values of a row inserted into the WebDataGrid into another table. However, the code I've leveraged from a previous application isn't quite working. Could someone take a look and get back to me? The two lines which are causing me trouble are those which declare "insertedItem" and "parentItem" (I've bolded and underlined the errors). I'm not entirely sure I'm using the correct event argument. Perhaps that has something to do with the issue? I need to resolve this today, as I'm giving a demo to our board tomorrow (who will be making a choice on which third-party control provider to use).
Protected Sub wdgResourceGroup_RowAdding(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.RowAddingEventArgs) Handles wdgResourceGroup.RowAdding
Dim insertedItem As GridEditFormInsertItem = DirectCast(e.Item, GridEditFormInsertItem)Dim parentItem As GridDataItem = e.Item.OwnerTableView.ParentItem
Dim datakey As String = parentItem.OwnerTableView.DataKeyValues(parentItem.ItemIndex)("FacilityID").ToString()Dim contactId As Integer = CType(insertedItem("colContactId").FindControl("cboContactID"), DropDownList).SelectedValue
Dim conn As New SqlConnection(ConfigurationManager.ConnectionStrings("BRAVA_ConnectionString").ConnectionString)
Try conn.Open()
Dim cmd As New SqlCommand("FacilityContactAdd", conn) cmd.CommandType = CommandType.StoredProcedure cmd.Parameters.Add(New SqlParameter("FacilityID", datakey)) cmd.Parameters.Add(New SqlParameter("ContactID", contactId))
'Dim insertQuery As String = "INSERT into FacilityContacts(FacilityId, ContactID) values('" & datakey & "','" & contactId & "')" 'Dim cmd As New SqlCommand(insertQuery, conn) cmd.ExecuteNonQuery() conn.Close()
Catch ex As Exception wdgResourceGroup.Controls.Add(New LiteralControl("Unable to insert contact. Reason: " + ex.Message)) e.Cancel = True Finally End Try
End Sub
Hi MartinWright6
I have been researching both GridEditFormInsertItem and GridDataItem classes but it seems to me that they are not part of the Infragistics libraries. Most probably they are part of any other third party control provider and I am not familiar with them. I would suggest that you insert the desired values from the WebDataGrid to the other table's data source directly, if at all possible.
