I can't get the AjaxIndicator to work with the WebDropDown control. Can someone point out what I'm doing wrong?
Also, when the AjaxIndicator is working correctly, will it prevent the user from selecting a value in the WDD while the new values are loading?
I've attached my code as zip, and here is a quick preview:
Here is my markup:<ig:WebDropDown ID="WebDropDown1" runat="server" Width="200px" DropDownContainerWidth="200px" DropDownContainerHeight="200px" onitemsrequested="WebDropDown1_ItemsRequested" EnableAnimations="false"> <AjaxIndicator Enabled="True" Text="Loading WebDropDown1..." RelativeToControl="True" Location="MiddleInfront" /> <ClientEvents DropDownOpening="_DropDownOpening" /> </ig:WebDropDown>
Here is my ItemsRequested event handler:
protected void WebDropDown1_ItemsRequested(object sender, Infragistics.Web.UI.ListControls.DropDownItemsRequestedEventArgs e) { System.Threading.Thread.Sleep(3000); // simulate a long database call string id = System.IO.Path.GetRandomFileName(); WebDropDown1.Items.Add(new DropDownItem(id)); }
Hello ssd,
When using loadItems(), the progress indicator is disabled and that is why it is not shown
//in the IG js file
if (this._pi) { this._pi.set_enabled(false); } this._callbackManager.execute(cbo, true); if (this._pi) { this._pi.set_enabled(true); }
Anyone have any thoughts on this?
