415
Row selector missing when row selected using JavaScript
I have the following code to select a row using BLOCKED SCRIPT
function DataGrid_SetSelectedRow(gridName, row, setActive, clearSelection) {
    var grid = DataGrid_GetGrid(gridName);
    if (!grid) { ErrorHandler_Error('DataGrid_SetSelectedRow''Unable to find grid.'); return; };
    var behaviours = grid.get_behaviors();
    if (!behaviours) { ErrorHandler_Error('DataGrid_SetSelectedRow''Unable to find grid behaviours.'); return; };
    var selection = behaviours.get_selection();
    if (!selection) { ErrorHandler_Error('DataGrid_SetSelectedRow''Unable to find grid selection behaviour.'); return; };
    if (clearSelection == undefined) clearSelection = false;
    if (clearSelection == true)
        selection.get_selectedRows().clear();
    if (row == undefined || row == nullreturn;
    selection.get_selectedRows().add(row);
    var activation = behaviours.get_activation();
    if (!activation) { ErrorHandler_Error('DataGrid_SetSelectedRow''Unable to find grid selection behaviour.'); return; };
    if (setActive == undefined) setActive = true;
    if (setActive == true)
        activation.set_activeGroupedRow(row, true)
The row is selected as expected but the row selector and row number is missing
until I actually click the row. The row selector is just a white square. I whought
I thought I might need to make the row active so I tried that too but still cant
get it working.
  • 19693
    Verified Answer
    Hello Rich,
    You are correct you are missing the active row and you can make it active by setting the active cell:
            var grid = $find('WebDataGrid1');
            var row = grid.get_rows().get_row(2);
            grid.get_behaviors().get_selection().get_selectedRows().add(row);
            grid.get_behaviors().get_activation().set_activeCell(row.get_cell(0));
    activeGroupedRow is used when Grouping ( of WebHierarchicalDataGrid ) is enabled
    Let me know if you need further assistance regarding this.
