is it possible to copy a defined Row with formated Cells in an Excel Templatefile to fill Data from an Datasource?
René
Hello Rene,
Let me know if you have some additional questions.
I have created a new feature request on your behalf based on the requirements described in your second post.
Your reference number for this feature request is FR13282 – “Ability to copy, insert and delete cells from Worksheet with formatting included.”
To follow up your feature request you can contact Developer Support Management via following email address – dsmanager@infragistics.com
Thank you for your request.
Thank you for your feedback – it is now clear what kind of functionality do you require.
I will log this request in our feature tracking system and I will respond to this thread with the number of the Feature Request.
Oh I see, so you would like a way to insert/cut/copy/paste/delete rows, columns, and cells? This is currently not supported but I know it has been requested already. I will have someone from DS add another request for this feature on your behalf.
Hello, thanks for your answer, but I thik we talk about two diffent things.
What I mean is I need a Function that copy a cell from Worksheet like
row[index].copy();
This function copy all Formats from the row including formula, colors, values and conditional formattings. After that I need a function that insert the row into a new row like
row[index].insert();
Also we need other functions e.g.
row[index].Add();row[index].Delete();
column[index].Copy();column[index].Insert();column[index].Delete();
We also need a function for AutoFilter?
Is it possible to do this with the excel exporter?
