On my Master Page I have a WebDataTree with static Parent Nodes and I dynamically load the Child Nodes from a dataset. When populating the NavigateURL property the first tim around, the path is fine (ex: ~/_ChildFolder/mywebpage.aspx). When I click on a node, thus causing a postback, the target page loads just fine, however, when I go to click on the menu at that point, the folder name has been duplicated, so it is now ~/_ChildFolder/~ChildFolder/mywebpage.aspx....I have stepped through the entrire codebehind one step at a time and nowhere can I find where this is happening. My version is NetAdvantage ASP.Net v10.1. Please don't suggest I upgrade to 10.3 because I can't. Is this a known issue and/or has anyone observed this before?
In playing with this further after submitting the post, I found a fix. I was able to circumvent the behavior of the node determining the 'actual' path from the virtual path provided. What I did was to pull the base path (http://mywebsite/) from the Request.URL property and concatenate it with the 'virtual' part of the path provided (~/mysubfolder/mywebpage.aspx) to the node.NavigateUrl property and combine them into one string (http://mywebsite/mysubfolder/webpage.aspx ). This successfully bypasses the default behavior of the node which is incorrectly determining the actual path and adding the last clicked folder to all the nodes (http://mywebsite/othersubfolder/mysubfolder/webpage.aspx). Since the menu is built recurssively from a dataset, it was only 2 added lines of code. Thanks for the qucik response though.
In order to look in to this, I would appreciate if you can provide me with the mark up of the tree as well as the approach (code) you are using to add nodes.
Bhadresh
