1140
WebSplitter not sizing properly inside an UpdatePanel
The WebSplitter is not filling 100% height when dropped into an UpdatePanel from Safari and Chrome (works fine in IE and Firefox).   The UpdatePanel contains a Div panel set to 100% height/width and it is the parent of the WebSplitter.  Here is the markup:
 <ig:SplitterPane runat="server" Size="65%" ScrollBars="Hidden">
        <Template>
          <div class="AvrioModule100Percent">
            <asp:UpdatePanel ID="UpdatePanel1" runat="server" RenderMode="Inline">
              <ContentTemplate>
                  <ig:WebSplitter ID="igSplitTree" runat="server" Orientation="Vertical" Width="100%"
                    Height="100%" DynamicResize="true" ResizeWithBrowser="True" Enabled="true" EnableAjaxViewState="true">
                    <Panes>
The stuff inside the splitter (i.e., the tree and associated grid, each in a separate pane
                    </Panes>
                  </ig:WebSplitter>
                </div>
              </ContentTemplate>
            </asp:UpdatePanel>
          </div>
        </Template>
      </ig:SplitterPane>
Any ideas as to what we need to do to get this to work properly in Chrome and Safari.
